12v c90 front rack
12v c90 front rack
As in the title I’m looking for a c90 12v front rack for a square headlight model, cheers Ian.
- Rides:: SH300 (2016),'88 C90MG,'94 & '95 C90P, '98 C90T & other 12v sq h.lt models.
Re: 12v c90 front rack
Hi Ian, if you type in to google or whatever:-
81100 - GK4 - 760
That will bring up some photos of the Honda rack that I know will go on at least an '86 onwards Cub. Probably the earlier aswell but cannot confirm!
There's suppliers on there aswell but your local dealer can probably order for you?
Anyway, that's the part. You need a tubed spacer and longer bolt for the main fork centre fixing! The side legs fix to the small threads in the side of the forks. If there's nothing screwed in there now (reflectors etc), may be worth trying a bolt with oil or running a tap in to them to clean them up? Don't use to much force... they're only like 'thread nut' fittings.
Hope this helps, cheers Andy.
81100 - GK4 - 760
