chaly
- steveST100
Re: chaly
6v and 12v taps are not the same.
This is the 12v type,6v has a flange that has two screws to fit it to the tank.
Re: chaly
http://www.ebay.co.uk/itm/PETROL-TAP-FU ... Swo8hTl4BC
If you're not in a hurry Barker, they are available for about ten quid post free from China.
Re: chaly
Sorry Barks, I didn't read your post properly. Have you tried Silvers(like AlanCF said) or try this link below. There are loads on ebay, but be sure to measure the thread on your petrol tank to get the correct size. A lot of the Chinese bikes use this kind of tap so you might get lucky at your local bike breaker.http://www.ebay.co.uk/itm/Motorcycle-Pe ... 2220161272
- steveST100
Re: chaly
Had a play with some bits in the garage today and found that the tap from a TL125 fits.
Only problem is the outlet is on the other side and the tap bits are riveted same as the CF70 one,but its a start as have drilled the plate off before and drilled and tapped them. Think the thread size is 14mm.
Both taps.
Both taps.
