plop project
- Rides:: Honda c90
Re: plop project
What diameter did you go for?
- Rides:: retro's
Re: plop project
hi
The one i got was to fit a 28mm end can.
This one...
http://www.ebay.co.uk/itm/272484292036? ... EBIDX%3AIT
This one...
- Rides:: retro's
Re: plop project
Looking good fazey ,as they say "See you track side"
- Rides:: ZX9R, RD500LC, RG250III, RS125SP, WR450F, TC250, REV3 250 and 2 Cubs!
Re: plop project
Looks great, but your foot pegs are way too low. They'll touch down at the first sight of a corner, we tried some like that, they nearly chucked me off on the first test ride round the block
- Rides:: retro's
Re: plop project
Footpegs are at the welders being moved up an inch. i did touch the footpegs down when we took it for a test.
Where did you get other higher footpegs from ? just incase the ones being welded dont work.
I have some original ones but the holes are in a different position on a lifan engine.
I will also have to weld the gear lever as i wont be able to get the bolt in if i lift it higher.
Re: plop project
You can put the bolt in from the other way (one a bit longer ) then put a nut on it on the back side and it will still tighten up .
- Rides:: retro's
Re: plop project
Did think about that Ian but was worried some aggressive gear changing might knacker the splints. Have had it cut and welded the other way round.
Re: plop project
Ok pal ,as long as your sorted ,6 weeks today
- Rides:: retro's
