CG125 stuff.
Re: CG125 stuff.
My mate nuno at work is Portuguese he ordered me my ybr125 170cc big bore kit from a site that was in Portuguese
- johnxl
- Rides:: 85 C90m, 79 XL185t, 62 C102, DR350.
Re: CG125 stuff.
On the page you want, try right clicking on your laptop/mouse and select translate. Worked for me. R$ 44,59 = £7.88.Alan CF wrote:Anyone speak Portuguese, im after one of these cams, to test,
http://www.macrovirtual.com.br/moto-pec ... gk-1010851
- Alan CF
Re: CG125 stuff.
Thanks, I had done this but when i get to inputting my details it asks for my CPFjohnxl wrote:On the page you want, try right clicking on your laptop/mouse and select translate. Worked for me. R$ 44,59 = £7.88.Alan CF wrote:Anyone speak Portuguese, im after one of these cams, to test,
That means, ( i had to search )
Best Answer: Cadastro Nacional da Pessoa Jurídica – CNPJ
National Census of Juridical Person.
It is a number which identifies a Juridical Company together with the National Reserve. This is done so the the conpany has the capacity to enter contracts, process or being processed, and also to be lialble to the IRS. It is basically the identity of a Company as a reliable entity.
Maybe you cannot enter the data because the numbers go usually in the following format: 03.847.655/0001-98. This means 03.847.655 these are the root numbers which identify the Company. 0001- Idendify the Activity of the company and, -98 Are the verifying digits.
This is basically for taxation and National Reserve services. It is basically when you register a Company in the name or a Juridical Person. It has to do with payments for IRS as company. It also refers to companies which want to do International Custom transactions.
CPF=Cadastro de Pessoas Físicas, which is basically the same.
hope I was able to help you. I hope this what you needed.
So it looks like you have to be a registered company within that country to purchase from them. ( no wonder these cams have not been seen around )
Re: CG125 stuff.
Send them an email.
- Alan CF
Re: CG125 stuff.
You clever bugger, Lets see if they reply.wightegi wrote:Send them an email.
- bigswifty
- Rides:: Honda C90 M-G, Innova 125
- Rides:: Rd Yamaha Innova
Re: CG125 stuff.
Alan CF have a look at this ,might be an Idea to contact this manAnyone speak Portuguese, im after one of these cams, to test,
http://www.dotheton.com/forum/index.php?topic=67378.0
- Alan CF
Re: CG125 stuff.
Thanks, Thats where i got the info from, then i searched the wsx and the part number and found the info above,rattle wrote:Alan CF have a look at this ,might be an Idea to contact this manAnyone speak Portuguese, im after one of these cams, to test,
Re: CG125 stuff.
Ah didn,t see that coming
Re: CG125 stuff.
I'm going to fit a replacement front brake caliper to my Lifan CG copy tomorrow. What type of brake fluid should I use and are there any special techniques required to bleed it properly? Compared to my C90,this hydraulic braking malarky seems very exotic.
