C90 Con Rod kit
Alain
Rides:: 1983 C90C
C90 Con Rod kit
Post by Alain » Thu Aug 04, 2011 12:09 am
Hi,
I recently had to rebuild my motor after the big end bearing went and had ordered this con rod kit from a place online.
They sent me the wrong one (it's for a ZZ, with the larger crank pin and different length rod and I've got a C90C) but i didn't realise until I'd opened up the packaging. Apart from having been taken out of the packaging to realise it was wrong, it's brand new (the rod, bearing and crank pin).
It's a Herng Der Machinery Works unit (new old stock).
I'd like £35 for it, including postage
Alain
Rides:: 1983 C90C
Re: C90 Con Rod kit
Post by Alain » Thu Aug 11, 2011 12:54 pm
Open to offers or swaps for other C90C bits
I could do with the headlight / ignition surround in blue or a nice seat cover...
bikehunter10
Rides:: 1975 C90
Re: C90 Con Rod kit
Post by bikehunter10 » Fri Aug 19, 2011 9:23 pm
Hi Alain,
If you still have this kit available to sell, I have some questions about it:
- Does the roller bearing have the rollers spaced in pairs?
- How many rollers are there?
- Can you post a picture on here of the components, or email me a picture?
Many thanks!
Simon Jones, Southampton.
Alain
Rides:: 1983 C90C
Re: C90 Con Rod kit
Post by Alain » Fri Aug 19, 2011 9:31 pm
Hiya
Yep, still got it. It is also listed on eBay (Item #: 150644321880) and the listing includes a picture.
I'll post the image on here as soon as I switch the PC on.
The rollers are spaced equally (individually) and if uncounted correct there are 20 rollers in the bearing.
Alain
Alain
Rides:: 1983 C90C
Re: C90 Con Rod kit
Post by Alain » Mon Aug 22, 2011 10:14 pm
As promised - here's a picture
Let me know if you want it, Simon :)
Alain
Rides:: 1983 C90C
Re: C90 Con Rod kit
Post by Alain » Mon Oct 24, 2011 9:35 pm
I've still got this :)
