Honda SuperCub C90G and T spares needed gone
Posted: Mon Sep 10, 2018 8:46 am
Hello again, I have found some more bits that need gone, prices will be symbolic and negotiable as I need them out of the way. Sold my daily C90s and I don't need these anymore:
Some bits have sold on the facebook page (big mistake in advertising there...) and these are:
- the 6V Rickman fairing
- Lifan stator + rotor
- front rim with spokes (left with a rear rim with spokes)
- both grab handles
What's left is:
- Almost complete seat (hinge assembly is incomplete, one tear on the side)
- 4 x shoe springs OEM new
- Pl, Silencer - 50385-GB4-000 - used part
- Upper handlebar cowl in used condition with one of the fixings damaged but still have the broken piece so could be glued?
- 2 x exhausts, one from a C90T, the other from a C50 Little Cub (50 won't fit a 90 without some mods)
- OEM new side stand bolt + nut + probably pattern spring.
- Pattern complete front wheel C90G type.
- 3 x bolt + nylock nuts + 2 x spacers for the Rickman rear carrier (the one with the side bag support) these fixings go on the indicator stem fixing location.
- 1 x JT front sprocket new 16T
- Some o-rings and 2 x valve stem seals for the C90G type engine (1986 - 1994?) + 2 gudgeon pin clips.
- Both caps for a C90MT E-Start LH engine cover. The one for the crank nut and the other one for the inspection (checking the flywheel markings for the T F marks) These are OEM new.
- 2 x? copper washers for the head stud top nut seal for the oil feed. New OEM
- 2 x valve stem seals for the C90T (1996-2002) New OEM
- 4 x rear shocks in Shuttle Blue.
- 1 x engine guard (this was received as a gift from Diesel Dave, so would accept just the postage fees for it... never fitted it so not sure how it fits).
- 4 x horns. One is pattern and works, not sure about the other 3. 2 of them might need tuning.
- C90G Square spaced indicators Rickman Faring + fixings. No clear screen with this one. Can be bought new. This one was never fitted so as new.
- Rear rim with spokes, cush drive rubbers
- 2 x mirror mounts (original risers) + 2 x LH threaded nuts + the 2 x rubber protectors that come over the nut and risers. These are all new OEM. So everything for the mirrors without the actual mirrors.
- 3 x ring sets, 3 x gudgeon pins, 3 x 2 gudgeon pin clips all new (pattern)
- 1 x ring set Original OEM, a complete lower dirtshield fixing set (long screw + spacer + washer all OEM new but not in their original wrappings), overflow or breather hose for the carb... not sure which one... probably breather. 1 magnetic sump plug and washer, 2 x in line fuel filters, 1 x set of cush drive rubbers, some front forks mounts, etc.
- 1 x brake shoes OEM new
- 1 x throttle cable used.
Feel free to ask anything. I'll take offers for all of these.
Thank you.
George M.
- both grab handles
What's left is:
Thank you.
George M.
