Parts for sale
Posted: Thu Oct 22, 2015 9:39 am
Some parts for sale ... If they are too expensive just say
Brand new CM 91 frame .. no numbers £300 no offers
C200 ... needs minimal welding underneath .. can come in various guises ( i.e as absolute bare frame and tank £130 add forks, speedo and front shocks £150 . Have got swing arm, front hub shocks to suit ... just let me know what you need. NO V5 for this bike but numbers are all there
6v engine with 2 barrels, a new piston and rings and an early carb and manifold £100 plus post
12 v motor ... has compression ... appears to have had a replacement barrel but has no stator, flywheel or clutch cover and will need a repair on head for exhaust studs .. £50
C50 LAE ( I think .... they fit the 12v square bars ) Parking brake switchgear x 2 .. 1 complete £35 posted and one missing a lever and a switch but a switch or donor switchgear will be included £27.50 posted
Side casings .... Lifan, zongshen and an old honda one ... could split or sell as one lot
Coils .... C50ac ... C90 c91 c200 £10 each plus post
Rectifiers C50/c100 cm91 c200 c90 £10 each plus post
CD 90 side casing £10 plus post
Stators and flywheels .... no idea what they are from. Medium sized flywheel has YX stamped on it ... £15 plus post
Carbs ... 2 x mikuni 22 mm ( copies i think ) plus have what i think is an original £25 plus post for the 3
C50 carb ( I think ) £12 posted
12v square lamp speedo 8k miles £10 plus post
12v square lamp seat bracket £5 plus post
LAC / 70c 90c seat bracket £10 plus post
Small oil cooler £15 posted
C90 front badge with light £5 plus post
Good c90 z2 / zz sidepanel £15 posted
