Hi will upload some pics to night ,
Tomos 50cc only 500 miles from new - got mot until may ( I don't have a certificate but it comes up registered as having mot with dvla) sorn at present (£16 for years tax !).The log books in the post.
The ped with mot needs some work I got it as a non runner, it was leaking fuel I swapped float in carb from the spares bike and now it kicks over and runs fine but the carb needs setting up as I can't get it to rev cleanly ( well at all tbh !) I have a Haynes to go with it and as mentioned a whole other bike for spares - that dosn't run and has no docs but turns over and is in good condition.
I havn't got time to mess around and have far too many projects already , this would be pick up only.
Any interest or questions drop me a pm,
Cheers,
Rob.
2 x Tomos 50cc 1 with mot, other for spares £200
- r80rob
- Rides:: 73 c70 with c90 110, 72 MZ es250 and a r80!
- r80rob
Re: 2 x Tomos 50cc 1 with mot, other for spares £200
Hi this is the spares ped in good condition - the carb is off , needs a return spring for kick start and has no spark or docs;
This is the one with mot ;
Sorry - i'm in Rochester Kent ,
The Tomos is a semi autto pull and go, basically when the revs are at a certain level it changes gear, there are two ratios.
Its two stroke and you have to mix yourself - I have dealers manaul and service book showing what mix to use and how to start it.
