Right the times come to sell this bike. The spacy took its maiden voyage today, and ive been told I need to thin out my projects as somthings gotta give. So its gonna be the puch annoyingly...
GOOD BITS
*MOT'D TILL APRIL
*70CC DMP KIT
*GENUINE 17MM BING CARB
*The amazing sound of the FUEGO exhaust
*NEW BOTTOM END BEARINGS AND SEALS
*NEW THREE SHOE CLUTCH WITH LIGHTENED SHOES AND BRACE PLATE
*TWIN EXTERNAL CONDENSORS
*KEY IGNITION SWITCH AND KILL SWITCH
*50CC HEAD FOR HIGHCOMPRESSION (COMES WITH NEW 70CC HEAD)
*NEW BRAKE SHOES
*NEW CABLES
*NEW TYRES
*FRESHLY GREASED EVERYTHING
*SMALLER REAR SPROCKET
*LARGER FRONT SPROCKET
*GENUINE SPEEDWAY DISCS ON THE REAR WHEEL (CUT DOWN)
*DROPPED BARS
SPARES INCLUDED
*original removed parts
*spare spoked wheels
*one front mag with speedodrive
*two pedal start engines and one kickstart engine + the one in the bike = 4 engines!!
*BRAND NEW GENUINE E50 CASE!!! I was going to use to build kickstart screamer!
*spare 70cc highcomp head
* 50cc barrel and piston
*15mm bing and foam filter
*original 14mm bing
*original sprockets
*tools for removing clutch and mag
*loads of other little bits inc new fuel tap, new main jet for repro 17mm bing.... clutches and more...
BAD BITS
*Doesnt come with brooks saddle (ill try find the one it came with)
*Declared sorn
*Big end bearing has gone I think..
^Not a big deal in that you could use a crank from one of the spare engines and have it going again in an hour.. Reason I havnt done this is, If I do... Ill innevatably want to keep it.. ;D
So there ya go... Its all there. LOADS OF MONEY spent since ive had it. Comes with all the spares FREE!! Just needs someone to spend an hour swapping a good crank into it. Which I promise you is a a realy realy easy job.
For all that id like the TINY SUM OF £250 But feel free to make me an offer... I might accept. :-[
1971 PUCH MAXI 70CC £250
- Rides:: CT90 K0, 76 CB550 , 76 MR250
