Charging yes or no !!
On the way to work this morning on the CB500 charge check light stayed red (no charge) so quick look when I got to work yes it is charging so it just the test light failed so I fitted this
http://www.ebay.co.uk/itm/170846277331? ... 1438.l2649
Inside my clocks
Dave
Yes bit of a bodger !!
Inside my clocks
Dave
- Jehova Empress
Re: Charging yes or no !!
If it's showing 11.8 volts when running,it's deffo not charging
- Rides:: Honda : C50M, NB50M, ST1100/Side-car, XLR125, Suzuki : Bandit 1200S, GSX 1400
Should be over 14v when running, no?
- Jehova Empress
Yes...12v battery should be at least 12.6 volts when at rest and engine off
Should be at least 13.5 volts when running and ideally 14 to 14 .5 when running
11.8 means battery is fcuked or charge circuit/reg-rec is goosed
11.8 v was engine off lights on ! seeing 14.5 with engine running even with lights on
enough trouble getting a picture without it running
Dave
Dave
- digger06
iv used those before, very good,
i found a waterproof one also on fleabay, thats on the trike (just a couple of quid more )
- Rides:: Suzukii Address i 2010,Honda 300i 2007
On my C90 i fitted a cig lighter socket and i have a multimeter with a cig lighter plug fitted as well as probes,i simply set the multimeter to volts(up to 20v) and plug it into the cig socket,rev my bike up to check max charge or test battery volts without the engine running,i can use the multimeter to check my van or anything else that has a gig lighter socket,i checked my neighbours tractor last week.
One of my next little jobs on my to do list is fit a cig lighter socket and a usb? socket for my sat nav,they are sat in my shed waiting for me to pull my finger out !
tom
tom
- Rides:: Red C90.
- Jehova Empress
More plugs than NGK
