Gulf Bike Oils New To Opie Oils
oilman
Post by oilman » Wed Jan 04, 2017 12:40 pm
Hi Folk's
Opie Oils sells the full range of Gulf Oil from Gear Oil & ATF to Engine Oils. Opie Oils are happy to say they have an extended their Gulf range with addition of Gulf Motorcycle Oils.
Opie Oils offer a range of Motorcycle Oils. We now stock and sell Gulf Motorcycle Oils from 2T all the way to 15w-50
Gulf Syntrac 2T Synthetic Low Smoke 2-Stroke Motorcycle Oil is a supreme performance synthetic lubricant specially developed for high output air cooled 2-stroke gasoline engines. Its unique formulation based on synthetic base fluids and advanced performance additives ensures excellent engine protection, cleanliness and low smoke even under extreme operating conditions.
Gulf Pride 2T Plus Semi-Synthetic Low Smoke 2-Stroke Motorcycle Oil is a premium quality semi-synthetic lubricant specially developed for high powered 2-stroke air cooled gasoline engines fitted with oil-injection or premix systems.
Gulf Pride 2T 2-Stroke Motorcycle Oil is a high quality lubricant suitable for use in air cooled 2-stroke gasoline engines deployed in variety of applications. It is blended from high quality base stocks and fortified with carefully selected additives to provide engine protection and cleanliness in 2-stroke engines.
Gulf Syntrac 4T 5w-40 a synthetic, 4-stroke gasoline engine oil developed specifically to meet the special requirements of latest high performance air cooled 4-stroke motorcycles. It is blended from premium quality base stocks and advanced additive technology to exceed the most demanding lubrication requirements of modern 4-stroke motorcycles.
Gulf Syntrac 4T 10w-40 it provides excellent protection to engine, gearbox and wet clutch used in 4stroke motorcycles and ensures highest degree of reliability even under severe operating conditions. It is suitable for wide range of ambient temperatures.
Gulf Power Trac 4T 10w-40 these oils meet the specifications of API SL and JASO MA2, and the requirements of leading global 4-stroke motorcycle manufacturers.
Gulf Pride 4T 10w-40 the product exceeds the international specifications of API SG and JASO MA for 4-stroke motorcycle oils and the requirements of leading global 4-stroke motorcycle manufacturers.
Gulf Pride 4T 15w-50 it is blended from highly refined base oils and performance additives to provide protection to engine, gear box and wet clutch used in 4-stroke motorcycles.
Should you need any advice on the correct product for your particular application, please feel free to give us a call on 01209 202 944 or drop us an email to sales@opieoils.co.uk and we will be happy to help. We’re here Monday to Friday 8:30 – 5:30
Until Next Time!
Opies
