c90 12volt stator plate
- Rides:: c90 +ttr 250
can any one help me get me spare engine fixed need 12 volt stator plate and card for same ,peter 07545642507
- Boo
Re: c90 12volt stator plate
Probably the cheapest way to get a stator is a Chinese one from ebay. I've seen them for about a tenner new from pitbike spares shops. make sure it's the right one for your flywheel.. Earlier C90 (up to 1993 C90N) had single lighting / charging coil and later one (C90P on) had 5. They'll swap between engines but the flywheel has to match the coil(s). I'm assuming it's not an electric start? Different shape stator but same early / late coil difference.
Is a card a carb?
Is a card a carb?
