Hello, I live in Zambia and have recently gotten into old Hondas. In my search for vintage bikes I have only come across 2 Honda C90s. I would like to try and get some info/advice on them before buying and attempting a restore project. The 2 I've found are in ROUGH shape so I'm wondering if its worth the effort/$$$ !?!?! Particularly I'd like to know the exact year of the two bikes. Look forward to chatting with new people about these vintage bikes.
-James-
Greetings from sunny Zambia
- Rides:: '76 Honda CT-90 : '73 Honda S110
- Rides:: Red C90.
Re: Greetings from sunny Zambia
Hello and welcome.
You'd need a little bit more to go on to be able to try and work out the age of the bikes, namely such things as frame and engine numbers.
- knapdog
- Rides:: '96 C90, '83 C90C, '98 Honda Valkyrie
Next time I'm out on Tojo I'll be shouting, "To Zambia and beyond!"
A very WARM welcome.
The second one had no engine. its' Chassis number said C90-5169048 ? Thanks for the help!
Anything is possible ,Have you got all of the engine in the photo ? Chinese pit bike engines can be fitted to all bikes some straight in others may need a bracket your 2 look like 6 volt 90s so will need a bracket .
