You need a tube on most spoked wheels. You CAN use tubeless tyres but you have to fit a tube. The only way to go tubeless is to fit alloy wheels....barker wrote:can you get tubeless tyres on a innover
Comments on my first puncture push home
Re: Comments on my first puncture push home
- jammy james
- Member formerly known as james cub
- Rides:: 1989 Honda 90 cub (elec start!)1988 honda cub. 2010 Suzuki fl 125 address+
I've ridden home a couple of miles with flat tyre,just keep the speed down!! Far easier doing it at home, for longer trips I do take tools plus tube...
I would reckon a couple of miles on a flat tyre would mean a new tyre & tube ?jamescub wrote:I've ridden home a couple of miles with flat tyre,just keep the speed down!! Far easier doing it at home, for longer trips I do take tools plus tube...
New tube certainly....Depends on which tyre and how well you can keep your weight off it. After 12 miles my rear was showing signs of distress but I actually think at a push i could have got away with not replacing it. The rubber wasn't visibly damaged and cubs are light, slow machines anyway.stevew wrote:I would reckon a couple of miles on a flat tyre would mean a new tyre & tube ?jamescub wrote:I've ridden home a couple of miles with flat tyre,just keep the speed down!! Far easier doing it at home, for longer trips I do take tools plus tube...
- Rides:: sunbeam s8,bmw f650,honda superdream
I use slime or gloop,and ive never been stuck with a puncture since I started using it, changing a tube at the side of the road in the dark,cold,rain is hopefully a thing of the past,it will repair a puncture upto 3mm, even if it doesn't repair it, it should stop rapid deflation and stop a buttock clenching experience
- digger06
it doesn't often stop rapid deflation, in a tube, because if the hole is pretty big, and by chance the gloop does stop it, the tube splits anyway,
well, that's what I have seen quite a few times, the other thing with that stuff is you never know if your punctured if it does work,
maybe not such a problem on a slow bike though...
I prefer to carry a tube,
- Rides:: 1966 S90 1998 royal enfield 350
At a push try ramming grass if available into the tyre !! better than nothing at all and helps in a miles from no where situation....
digger06 wrote:it doesn't often stop rapid deflation, in a tube, because if the hole is pretty big, and by chance the gloop does stop it, the tube splits anyway,
I cant disagree with what you say, especially if you have seen it a few times,but ive been using it for maybe 5 0r 6 years and have never been stranded with a puncture. it leaves a tell tail green mark on the tyre where the puncture is,its got me home with a puncture at least 3 times,once on a touring holiday in wales covering about 700 miles in a week I had a puncture at some point and didn't notice until I got home and washed the bike off but that puncture could of happened a mile from leaving home or a mile before I arrived back home,i don t know but I always change the tube asap
- Rides:: Peugeot Vox 110 cc
I don't want appear a 'know-all' but surely you people can be like the Scouts and ....Be Prepared'...and join a break down rescue organisation!! The only time I needed the AA was when I had a puncture in my rear tyre at 12.10am leaving my part time job. the local farmers were slashing the local hedgerows and I picked up a splinter. The AA turned up in no time to take me home and even phoned my wife to tell her what was happening...
