takegawa-07-06-0006-breather-pipekit-with-level-gaugemonkeygorill_big09060221-01_af8c.jpg
or similerThanks
i would look round the shops or ebay for pit bike stuff, they always have gizmos in bright coloudr to trick you into thinkin you wil get another 0.005 horsepower outta your engine....Janz wrote:I think he probably means where can he get one that won't cost a remortgage! CSM ain't cheap & neither is Tacky Gawa...
nah the fast boys put the end into a red bull can and cable tie it to the frame..... good for another 3mph top end so im told.....Janz wrote:What does this funky thang do anyway? I get the idea that it is part of an oil catch tank but where is the tank? Or does it blow the oil out in to the breeze or down your leg? Mount a catch tank to the top of the chain enclosure & drill a hole on the side of the tank near the top. Drill a hole in the chain enclosure at the bottom where the tank meets. Hang a bit of wire, some clear tubing or a cable tie in the tank hole & feed it down through the enclosure. When the tank fills up oil will flow down the wire & you'll have a cool chain oiler. You'll probably need to buy shares in Opec though!
