Can anyone please help me out with a c90 6v handle bar indicator switch or point me in the correct direction.
All I need to get it on the road
Indicator switch
- Alan CF
Re: Indicator switch
Use the cmsnl website to obtain your correct part numbers,
Don't buy anything using a disciption,
Cms are licensed to supply the public with part numbers,
Once you have the part number try Google or ebay first,
( using the part number)
If no joy then try David silvers.keep away from wemoto pattern crap.
- Rides:: 1971 c90
Many thanks for that , I tried a Chinese copy to swap the internal bits but failed as different.
Will get on cmsl later
