Crankshaft Wanted Please.
Bandersnatch
Rides:: Harley Chop
Post by Bandersnatch » Sat Sep 23, 2017 10:44 pm
Hi, people, is there any kind folk amongst you who have a Electric start crankshaft they would willingly sell for a reasonable price, the flywheel/stator side of mine is buggered due to rust, even that side moon of the crank would do, or even one with a knackered big end as I have a new big end kit to fit. Thank you.
steveST100
Re: Crankshaft Wanted Please.
Post by steveST100 » Sat Sep 23, 2017 11:28 pm
Kickstart and electric start cranks are the same,so any will fit.
Alan CF
Post by Alan CF » Sun Sep 24, 2017 11:57 am
And then there are two Sizes of cranks for the 12v 90, one has a 23mm big end pin and the other is 25mm.
The 25mm crank has two deep lines going all the way round on the flywheel side web, Its a easy crank to spot once the cylinder is removed.
Bandersnatch
Rides:: Harley Chop
Post by Bandersnatch » Sun Sep 24, 2017 4:18 pm
Bugger, got a 23mm pin crank and bought a 25mm big end !!! :evil:
This is where all you folks experience counts and dummies like me make presumptions !
Anyone help with a crank ??
Alan CF
Post by Alan CF » Sun Sep 24, 2017 5:03 pm
how about stripping the old crank down and trying to clean the web up if it comes to it,
reduce the shaft size before the web,(so it dont mess with the main) Then fit a 1mm smaller inside diameter seal to the stator plate.
Bandersnatch
Rides:: Harley Chop
Post by Bandersnatch » Sun Sep 24, 2017 5:33 pm
I think I would rather just find a crank, the machine work alone would out weigh the value of such an operation, and the face that's knackered has a needle bearing running on it from the starter / sprang clutch sprocket also, then that would also need addressing. Hopefully someone will have a knackered complete crank they will let go of !
Alan CF
Post by Alan CF » Sun Sep 24, 2017 6:24 pm
Ar Yes, Forgot its a lecky start, :(
Alan CF
Post by Alan CF » Sun Sep 24, 2017 7:35 pm
Might be able to help you there now, Your post on my ebay link says C70 12V. And the c70 crank is not the same as a c90 12v, The webs are smaller and the rods are not the same, I might have a c70 12v web.
Bandersnatch
Rides:: Harley Chop
Post by Bandersnatch » Mon Sep 25, 2017 12:44 am
Alan, if you have one to sell I would be grateful, it is indeed a 12v c70 1983, the side I want is the stator side and it has the male threaded end not the female ?? Regards.
bentwheel
Rides:: 1965 CM90, '66 CA77, '79 XS750, '83GR650
Post by bentwheel » Wed Oct 04, 2017 10:25 pm
Is a crank from a 90 pushrod engine any use to you?
