chaly
barker
chaly
Post by barker » Thu Jul 20, 2017 3:48 pm
have a 12volt 1982 chaly but in need of a fuel tap has any one got one or know were I can get one from
Alan CF
Re: chaly
Post by Alan CF » Thu Jul 20, 2017 7:56 pm
silvers, as i have just fitted a new tap for a chap on his chaly that is residing in my shed at the moment. he also bought the plastic lever.
steveST100
Re: chaly
Post by steveST100 » Thu Jul 20, 2017 10:23 pm
6v and 12v taps are not the same.
This is the 12v type,6v has a flange that has two screws to fit it to the tank.
barker
Re: chaly
Post by barker » Fri Jul 21, 2017 5:21 pm
that's the one im after so if anyone has a good one let me know
Harry Notts
Re: chaly
Post by Harry Notts » Fri Jul 21, 2017 5:56 pm
http://www.ebay.co.uk/itm/PETROL-TAP-FU ... Swo8hTl4BC
If you're not in a hurry Barker, they are available for about ten quid post free from China.
barker
Re: chaly
Post by barker » Fri Jul 21, 2017 6:54 pm
not the same is it
barker
Re: chaly
Harry Notts
Re: chaly
Post by Harry Notts » Fri Jul 21, 2017 10:19 pm
Sorry Barks, I didn't read your post properly. :roll: Have you tried Silvers(like AlanCF said) or try this link below. There are loads on ebay, but be sure to measure the thread on your petrol tank to get the correct size. A lot of the Chinese bikes use this kind of tap so you might get lucky at your local bike breaker.http://www.ebay.co.uk/itm/Motorcycle-Pe ... 2220161272
steveST100
Re: chaly
Post by steveST100 » Sun Jul 23, 2017 6:14 pm
Had a play with some bits in the garage today and found that the tap from a TL125 fits.
Only problem is the outlet is on the other side and the tap bits are riveted same as the CF70 one,but its a start as have drilled the plate off before and drilled and tapped them. Think the thread size is 14mm.
Both taps.
barker
Re: chaly
Post by barker » Sun Jul 23, 2017 6:18 pm
that's as you say a start thanks for that
