I have a 1991 C90G with a fairing but no mounting brackets and can't seem to find any anywhere. Does anyone have a spare set?
Andy
Wanted - Mounting brackets for a C90G 1991 rickman type fairing
- Rides:: Puch Maxi, C90, MSX125,Z250, Z650, Bandit 1200, KLE500
Re: Wanted - Mounting brackets for a C90G 1991 rickman type fairing
Rickman still make them but our bulk purchases through George seems to have the brackets as part of the full screen set. Have you tried Rickman themselves ?
I haven't but i have just found out the fairing i have doesn't fit. The indicator spacing is slightly out so just won't go on
The earlier bikes had the indicators mounted lower and nearer the headlight.Later ones like yours are mounted on metal brackets, it is possible to swap them over.
These are the high mounted ones, if i swap them over they will be way too low. The problem seems to be that the indicatorspacing is about 1cm or so too wide
- Anigai
- Rides:: Honda: 1983 12v C90G, 1997 FES250, 2015 CB125f, Suzuki: 1982 6v GN400L,
Mine are like that too with my fairing, I'm afraid when it comes to my bike force is the only way to get the fairing on but once it's there it stays there.
