kick start gears
- Rides:: Innova, Daelim 100 citi, Honda ape (genuine), Honda Ape (copy). Yamaha RD400.
kick start gears
Hi does anyone have a 21 tooth kick start gear that they are willing to part with ,, the 22 tooth standard one is slightly too big to fit with the gears I have ,, I am given to understand some z50/ c70/110 clone engines have the 21 tooth item.
- JohnS
- Rides:: .2019 Honda C125
Re: kick start gears
I believe the Lifan engine kick-start gear has 21 teeth and will fit. Search previous posts on this subject,to make sure.You should be able to get one from Pit Bike Spares (Google them)
Thanks for the advice, I tried pit bike spares, they were very helpful but did not have the parts I needed, oo racing were the same very helpful and tried hard but did not have the parts.
Eventually I ordered a used Honda passport kick start set up from the states, it took an eternity to arrive was way too expensive but it did the job.
